Topic: Is it possible to route channel outputs to a USB headset?
Hi folks,
Is it possible to configure TotalMix FX so that it can output the mix audio into a different playback device on the same PC?
I use a Babyface Pro and TotalMix FX to combine the audio from two different PCs. I use the Babyface headphone jack to listen to this audio.
I have a nice pair of wireless headphones, though, that I'd like to use but obviously cannot because they're USB. So, I have been trying to see if I can get TotalMix FX to route certain channels to that USB playback device. I can't seem to figure out if that's possible or not. I think I can only route channels to the physical outputs on the Babyface Pro, correct?
Re: Is it possible to route channel outputs to a USB headset?
Correct.
I have a good old UFX and I was thinking the same thing, what if USB could be used to output mains to usb headphones?
I just bought a pair of 7.1 (real multi speaker) headphones and they do sound great, but it makes the workflow with changing soundcard a bit slower. It's quite a niche feature request I'm sure but maybe one day the developers will want something special for a hackathon and this will pop up, or for future devices USB headphones support will look great on a box wink
Fireface-UFX, Mac OSX 10.6, Logic 9, BCF2000, AC-7 user, vocalist, live sound recording
4 (edited by ramses 2020-03-18 08:45:09)
Even if something like this would be possible (see ASIO4ALL) I can hardly imagine that a manufacturer like RME would be interested in developing this. RME would then get support requests, even if the problem was with the 3rd party USB headset or other audio device. No company could be interested in such a setup without clear separation who is responsible for what.
RME solutions are more professional solutions where you follow a best practices approach and this is to load an highly optimized and stable ASIO driver on DAW level.
If you don't care about lowest possible latencies you can try ASIO4ALL. In this case the ASIO4ALL driver would have to be loaded in the DAW instead of the highly optimized RME driver. But this adds latency to the setup and any potential stability problem with ASIO4ALL or the 3rd party device could impact also the stability of the whole DAW setup.
The question is whether you as an RME customer bought RME to get at the end of the day an error-prone non-standard setup, which even can't be officially supported.
BR
Ramses
