Topic: Cue Mix Strange Behaviour
Using a UFX over USB and OSX High Sierra, CUe Mix button for Phones 2 is not working. All other Cue mix buttons work fine either by mouse or from MIDI control surface. You can click it and it lights while holding the mouse but if you let go it goes off again.
Assigning Phones 2 to a different output the issue is still there. I use 5 pairs of Phones  and 2 pairs of control room monitors. Cue mix button works fine on every other output.
I also tried turning off all MIDI serviecs to Totalmix and no change.
Any thoughts?
__________________________
Paul Najar
Jaminajar Music Production
www.jaminajar.com
Re: Cue Mix Strange Behaviour
I expect 'Cue/PFL to' is assigned to Phones 2 in your setup. Then the Cue button won't work (stick) as it makes no sense to listen to itself...
Thank you Matthais. That was it. It got me tricked in the heat of a busy session yesterday.
Kind regards
Paul Najar
www.jaminajar.com
