Topic: Weird MADI Clock speeds from UFX+
When using my UFX+ as a master clock via Madi optical, the slaved Eventide H9000 shows weird clock speeds when setting the UFX+clock speed to 44100Hz.
The H9000 shows that it's locked, but the actual rate reads either 44082Hz, or 44122Hz.
Other speeds show correctly as 48000Hz or 96000Hz.
I haven't had glitches in audio so far, but is this behavior expected, or is there something wrong with either my UFX+ or the H9000 Madi card?
If I use the H9000 as master, UFX+ shows the samplerate correctly as 44.1kHz.
I'll be connecting adat devices to my UFX+ too, so I thought it might be good to use the UFX+ as a master clock, but this seems weird to me and makes me think twice.
Thanks for help!
