Topic: BabyFace pro input voltage level
Hello everyone,
I would like to compute the sound pressure level of recordings I made with the BabyFace pro.  I already know the sensitivity of the microphone and the gain applied by the amplifier but I cannot find any information on the input voltage range of the sound card.
Does any of you know where I can find the maximum and minimum input voltage of the analogic inputs of the BabyFace pro?
Thanks in advance for your help.
Re: BabyFace pro input voltage level
Tech specs in manual, then convert dBu to Volt:
http://www.sengpielaudio.com/calculator-db.htm
