Topic: Problems with RayDAT, it may be sync/clock but not sure
Hello, thank you for maintaining this forum, it's been wonderful coming here over the years and reading topics. Now I come to you for help.
My RayDAT card is having problems:
-Boot into Windows for the first time in that day, open up DAW, playback works. TotalMix shows activity in the meters and Hammerfall DSP Settings show Sync 48k on my ADAT1 port coming from my Fireface UCX (more on this later). Clock source is set to Internal (Current: Master). On my Fireface USB Settings Sample rate is set to 48k (Current: 48k) and Clock Source Optical In (Current: ADAT).
-After a little bit of time playback in my DAW stops working. It freezes and won't allow me to resume/stop anymore no matter how many times I restart it (Bitwig Studio and Ableton Live in my case). TotalMix now shows no activity in the meters and Hammerfall DSP Settings show No Lock on my ADAT1 port. Clock source is still the same. On my Fireface USB Settings Sample Rate is now red and is set to 48k (Current 44,1k) and Clock Source Optical In (Current: ADAT).
-If I reboot the system, it works and doesn't freeze again.
This happens every single day and I would like to fix it. It started happening around the time I got my UCX. It acts as my AD/DA and as a backup interface should the RayDAT have trouble. The RayDAT and UCX are connected with two ADAT cables, RayDAT is the master clocking wise. The UCX is connected to my PC with a USB cable. The freezing happens even if the Fireface is not connected to the PC via USB, I just don't see the Fireface USB Settings obviously. I'll report tomorrow if it happens when the UCX is not connected to the RayDAT at all as well.
Windows 10 64-bit
Bitwig Studio 2.5
Ableton Live 10
RME Hammerfall DSP 4.22
RME Fireface Hardware Revision 46, Driver Revision 1.167
