Only to mention it .. It's also possible to silence a PC which is also very beneficial for work on the computer.
I took the challenge motivated by a german computer magazine to build this 0.1 zone PC.
Looking back it's very easy to achieve this even when using a Supermicro server mainboard, where the blower control is more designed for a server room, but even that was possible to be solved entirely.
Major components:
Predampened Fractal Design Computer Case which has a brilliant 5/9/12V switch which enables to run the 4 silent fans at even lower speed making them extremely silent.
In summer you can run them with 9V if required, still silent.
Special BeQuiet fans that are very silent and still deliver good throughput (I use 4 in my case) that are able to start and run with only 5V.
Noctua or other Tower CPU Cooler with many heatpipes and a special low noise cooler that works good in combination with the blower control of your mainboard for CPU.
Power Supply with hybrid mode switch that allows to turn down the blower of the PSU if the load is not high (in fact I never saw this fan moving).
Graphic card with zero fan mode. In case of good luck the fan is even not moving when enabling VSYNC in games which do not push the GPU hard and if it stays under 60°C.
Components see here:
http://www.tonstudio-forum.de/blog/inde … mponenten/
Then you can use a 15 (maybe up to 20m) long toslink cable to connect RME recording interface via optical SPDIF or adat to the ADI-2 Pro/DAC in front of your HiFi.
If you use ie MusicBee then you can control the player ie via an android app MusicBee Remote.
Just a thought, that's what I currently do.
