Topic: TotalMix 1.63 uses GPU even with closed window
Hello RME forum!
I have an issue with TMfx, probably since the latest update but maybe before that.
I mainly use my machine for multicam editing and multitrack audio mixing.
So when editing, I need my Arc USB to control my mains' volume (with TotalMix running in the background) and that's all,
in order to keep my GPU dedicated to video streams playback. But:
The software is using about 50% of my GPU when the window is zoomed at 135%.
It can drop to +- 40% when zoomed 100%. If I zoom the window at 70% and put it in the dock, the GPU usage finally drops to +- 10%, and I can work with 90%.
Is there a way to manage TotalMix graphics? For instance, can it only use the integrated graphic unit of the CPU?
I get GPU overloads if I forget to unzoom the mixer's window, that's annoying.
Thanks for reading and sorry for my poor english
• TotalMix Version 1.63 MAC OS X (1)
Fireface 802 (23795849)
DSP-SW Version: 9
Error Number: 0
Diagnostic Results: 18, 0.0, 0
• macOS Mojave
10.14.6 (18G95)
• iMac (Retina 5K, 27-inch, Late 2014)
4 GHz Intel Core i7
24 Go 1600 MHz DDR3
AMD Radeon R9 M295X 4 Go
• Fireface Settings
V 3.36
Kernel driver v3.36
