1 (edited by KMusic 2019-10-07 01:37:32)
Topic: Hardware&Diagnosis Missing?
So, i was looking at the forum about a problem with my DSP effects not working in a UFX.
Most if not all posts sugguest to run a Hardware&Diagnosis test.
So i go to my unit, hit setup/rev and try to find it in option... Nothing!
The only thing is there
1) Reverb Echo, Has only Reverb options, Echo are missing
2) Oprions -> Control Room
3) Setups -> Load/Store all settings
Of course i hit the down button (Press 2) to scroll through the menu.
Is it possible to missing a hardware option?!
Unit is running over USB on Win10 1903
Thanks in advance.
Re: Hardware&Diagnosis Missing?
Handbook 23.2
SETUP/REV.
Encoder 1 selects Setups, Options and Reverb/Echo.
   Options has the subpages Clock Options, HW Options/Diagnosis and Control Room Options.
   Reverb/Echo has the subpages Reverb and Echo.
The subpages are selected with encoder 2.
Thank you for your reply, was pressing instead of twisting.
Unfortunately needs service, is corrupted. hmm
