Topic: Delay Output Signal
Hi, is there any way to delay the output signal?
I am asking as I am running a double bass array and the dsp needed introduces 1or 2 ms delay. I can run the tops through the dsp as well but I am certain that the da converters in the babyface are better than the ones in the dsp so it would be great to have the mains on the babyface directly, delay the output according to the dsp and do a lowcut so the bass is generated by the dba and my tops just play evereything above 100 Hz.
