1 (edited by jerjabs 2019-10-12 04:28:53)
Topic: Is it possible to re-route recorded 1/4 inch guitar...
Is it possible to re-route recorded 1/4 inch guitar part recorded with my Babyface Pro into Logic back out into outboard guitar gear?  I'd like to record a clean guitar part and then re-route it into my Fractal AX8 unit.  If so, how?
Thanks for your time!!! smile
Jerry
Re: Is it possible to re-route recorded 1/4 inch guitar...
Yes its possible, but for this purpose the BBF Pro has not enough ports for a permanent cabling
(to make it more comfortably from operational perspective).
This is how I do that with an UFX+, do you speak german ?
https://www.tonstudio-forum.de/blog/ind … arren-Rig/
https://www.musiker-board.de/threads/wi … st-8775458
But you could perhaps try to use the phones output to plug it ininto the guitar amp and route the signal accordingly.
You do not need an UFX+/UFX II but something like a UC or UCX would offer more ports to you.
Use the headphone out into the fractal and back into the xlr’s with gain to 0 and pad on
www.yila.co.uk
