Topic: Power amp connect
I'm a new owner of ADI-2 DAC. My setup is as follow: ADI-2 DAC --> XLR --> Headphone amp (Airist audio Heron 5) & ADI-2 DAC --> RCA --> Power amp (nuForce STA-200). The ADI-2 DAC match with Heron 5 as expected and this couple drive my HD800s like never before. However, I got trouble when trying the ADI-2 DAC as a preamp. Please help!
My question is:
1. What happens with Auto Ref feature if I turn on both headphone amp and power amp. I have never done that wink
2. If I turn off Headamp, turn on the Power amp and Auto Ref Level set to on --> I have Auto Ref Level set to - 5dBU, the volume setting is fixed at -21dB and I can not adjust the volume. The speaker is too loud. Is there any volume lock setting that locked my DAC volume in this case? And is this a "level mismatch" between ADI-2 DAC and nuForce STA-200? Can inline attenuator (-12dB) fix this problem?
Thank you all in advance for your support!
2 (edited by N00b 2019-10-24 11:10:45)
Re: Power amp connect
Hi Zimumahi.
You should really read the manual for these issues.
https://www.archiv.rme-audio.de/download/adi2dac_e.pdf
Question 1: on page 38, section 19.6
Question 2: "Lock volume feature" on pages 21 & 62, "Auto Ref Level" on pages 20 & 37  smile
Hi N00b,
Thank you so much for your support. I've just detected the problem regarding DSD Direct mode set ON. With this mode, I can not adjust the volume.
However, your support is valuable to me. I realised that my printed manual is out of date. There is no section 19.6 on page 38, not paragraph about "lock volume feature"... I have downloaded the pdf manual (v1.8) on RME website. Again, thank you for your support!
4 (edited by N00b 2019-10-24 15:04:04)
zimumahi wrote:
Hi N00b,
You're welcome! smile
And for DSD direct with fixed volume, it is absolutely normal, you can read explanations about that on pages 16, 26 and 32.
And yes, a lot of features are added month after month, it's better to download the latest manual on RME website (even if the printed one is a very nice object!).
