Topic: HDSPe MADI FX multiple client ASIO
Hi I noticed in the specification below this card seems to support multiclient.
https://www.archiv.rme-audio.de/downloa … difx_e.pdf
quoting below:
"RME audio interfaces support multi-client operation. Several programs can be used at the same time. The formats ASIO and WDM can even be used on the same playback channels simultaneously. As WDM uses a real-time sample rate conversion (ASIO does not), all active ASIO software has to use the same sample rate."
So I guess the ASIO driver written for HDSPe MADI Fx works with multiple client? Is there any restrictions how the software is written (eg. written using the template ASIOSDK 2.3 "hostsample"), or if the software is 32/64bits?
Just asking because for Asio4all driver and steinberg's multiclient server a lot of softwares just don't show up in the multiclient server window. Not sure if it's the case for HDSPe MADI FX's driver.
