Topic: Safe to connect Fireface 400 to Thunderbolt 2 via Firewire 800?
Hi folks -- I have two pieces of hardware to connect:
Mac Mini (2014) which has a Thunderbolt 2 port
Fireface 400 from about 2007 which has a Firewire 400 port (IEEE 1394)
It's hard to find a direct Thunderbolt 2 to Firewire 400 adapter, so I'm going to use a Thunderbolt 2 to Firewire 800 adapter connected to a Firewire 800 to Firewire 400 adapter in sequence. Has anyone done that successfully, and is there any risk to the equipment if I try it? Am I likely to introduce extra lag because I'm using adapters?
I'll probably use these adapters:
Apple Thunderbolt 2 to FW 800 adapter: https://www.amazon.com/gp/product/B00SQ … _qh_dp_hza
CERRXIAN FW400 6-Pin Female to FW800 9-Pin Male Adapter (also on Amazon)
FYI, I'll power the Fireface unit externally and I'm not using more than one Fireface unit in the setup.
I searched this forum for this situation but no one asked about this type of connection. Thanks a bunch for any advice!
Jack
