Topic: Fireface UFX II Seeing signals when sample rate is set higher than 96
I notice when I set the sample rate to anything above 96K I see some signal on all the analog imput channels on the unit and in Totalmix. I'm assuming this is noise but I don't hear anything. Is this normal?
BobV
Re: Fireface UFX II Seeing signals when sample rate is set higher than 96
Yes is ultrasonic noise
