Topic: Can I play iPad audio when using TotalMix FX stand-alone?
Hi all
Does anyone know if I can play audio from my iPad into a UFX+ WHILST the iPad is being used to control the UFX+ (as a stand-alone unit) with TotalMix FX? My scenario is that I’d sometimes like to use a UFX+ as a mixer with a small band, controlled by an iPad running TotalMix FX. However, I’d like to also use the iPad to play background music during breaks. I assume that I’d just route audio from the iPad via the 3.5mm output and run this into a stereo input on the UFX+. This sounds logical to me but can someone let me know if this scenario would be feasible?
Cheers
Gary
Re: Can I play iPad audio when using TotalMix FX stand-alone?
The UFX+ is in CC mode then and the whole purpose of that is to be used with an iPad as recorder/playback machine. And you need TM FX for iPad to control the UFX+ at the same time. 3.5 mm output into UFX? That's like pushing your car while the engine is running...
3 (edited by Maddcow 2019-11-30 14:00:47)
So what solution do you propose, MC, if I'd like to use the UFX+ and TotalMix FX (on an iPad) as a digital mixer in certain situations....and I require background music? Use yet another device?
My UFX+ has been ordered but will take another few weeks to arrive....so I can't test anything at the moment but need to research as much as possible so that I can get the system up and running ASAP once it arrives.
Perhaps I've misunderstood: is it possible to simply play back audio (using iTunes or other iOS app) through the iPad's lightning<>USB connection to the UFX+ whilst TotalMix FX is also running?
5
Of course.
Ah great.  That's all I need...thanks heaps MC!
