Topic: Can't run 96k session on Pro Tools Win10 Fireface 802
Hello. New Pro Tools Install on Win10 Home (i7-5930k 3.50GHz/32GB ram). Fireface 802 via USB. Latest version of Win10 and Pro Tools. I believe I have the latest RME driver. Fire USB Settings> Date 27.06.19> 1.168 >13
Everything is perfect until I open a 96k session. Had Pro Tools error -6007 and then -6117. Started running Pro Tools as Admin and disabled all sound devices as recommended for those errors by Avid (also have a USB headset plugged in "KAVE 5.1" now disabled, was enabled when running 48k sessions no problem). Fireface USB Settings is switching back and forth with my Pro Tools sample rates. Still have error -6117.
When in 96k I'm getting clicks and pops in the system before disabling all sound devices. When in 96k now pro tools opens but give dialog to save and quit once my session is up. "PT unable to reacquire the hardware because it is used by another application".
Switching back to 48k session, it runs smooth.
I apologize if this is an obvious issue. Please enlighten my ignorance if you understand my problem. Thank you for reading.
