Topic: ARC USB Midi to Sonarworks possible?
Hi!
First off: I usually have nothing to do with Midi, so please excuse my ignorance.
I have a UFX+ with the ARC USB connected to my computer.
Sonarworks 4.4 has the possibility to load calibration profiles by Midi Input, so I thought it
would be convenient to load profiles automatically as I switch from Speaker A to B via my ARC.
I can only get Sonarworks to receive Midi if I check "SysEx only" in TotalMix ARC Settings, but
then TotalMix doesn't react to the Remote anymore. What would be the right way to do this?
Also might add this:
I use Midi on UFX+ Port 1 to control my Octamic XTC on Madi 9-16.
Can't use Madi for the control as I also have an Orion 32 via Madi which overrides Madi controls.
Best,
Frank
Happy Fireface UFX+, Octamic XTC and M-32 Pro user.
http://www.stoersender-studio.ch
Re: ARC USB Midi to Sonarworks possible?
Hi Frank!
Have you found a solution for this?
I wanted to do the same thing but I could not find anything so far. It would be very convenient to have TotalMix and Reference 4 switch presets at the press of just one button.
regards,
Dominique
Hi Dominique
No, I didn‘t try it via Midi anymore.
I made a shortcut in Keyboardmaestro so I can at least switch with a Keystroke.
Frank
