Topic: Hardware input not playing on my Headphone out?
Recently got my first hardware input via a monosynth which I connected via Instrument Line 3 on my RME Babyface Pro. In total mix I split 3/4 up from stereo to mono and corrected the panning after splitting.
I have no problems hearing the audio inside my daw when I set the correct input monitor channel to 3.
However I cannot hear this via my Main out for example if I want to use this without a DAW.
What am I doing wrong? Here is a picture of my Total Mix FX setup.
https://i.imgur.com/qu2Tcaz.png
Re: Hardware input not playing on my Headphone out?
From the  manual:
Usage in mode Submix View (Default)
Using TotalMix FX is really easy. Thanks to the Submix View (default) all you have to do is click on the Hardware Output channel in the third row where the audio signal is supposed to show up. This channel turns brighter, means it is selected as current submix. Now move the faders up from all sources – these are the input and playback channels, in the first and second row. That’s it. The input (monitoring) and playback (DAW software) audio signals are now available at that very output, which can be verified immediately from the level meters reacting accordingly.
