1 (edited by ghostmize 2020-01-08 10:42:18)
Topic: Traktor master/cue split not working
Hello
I am trying to use Traktor with the Babyface Pro, however I'm facing a strange problem.
I'm using Windows 10.
The cue function works, meaning I'm able to send the audio signal to the headphones only.
However, if the master channel of a deck is up on the Traktor mixer, it's also heard on the monitor(cue) channel..
What am I doing wrong?
I think somehow the Totalmix setup is wrong but no matter what I did I couldn't get it to work...
Also weird thing, If I mute for example the Left side of the main channel in Totalmix, I still hear a bit on the left speaker...so it seems related.
If I mute both left/right, then I hear the audio normally, as if I didn't mute anything (instead of hearing nothing)
thanks in advance!
Elad.
Re: Traktor master/cue split not working
First thing I would do is the total reset in Totalmix, menu Options / Reset options / Total Reset.
Then a proper routing and assign the main-out to the monitor speakers.
Watch all Youtube videos Totalmix.
There will be no Traktor preset as there are no other presets for any software player.
Traktor is a software and it's audio signal is visible in Totalmix in the middle row of channels, software playback channels, usually the first from left.
