1 (edited by jeandado 2020-01-10 16:37:00)
Topic: can somebody tell me why my loopback isn't working?
hi,
I want to use loopback von adat channel 15/16 to feed digicheck. (Mac)
it worked with my macbook, but not with my new studio computer.
both connected to the 802 via usb.
(totalmix 1.64, digicheck 0.73)
usually it should work like that...
somehow can't post picture, here is the screenshot:
https://imgur.com/a/02uhlv3
Re: can somebody tell me why my loopback isn't working?
macOS requires to allow the microphone for any recording software.
wow... @MC .... thanks a lot, now it works. however you knew that was the problem.... thank you!
another thing you might be able to answer easily:
I was told in theory the audio quality for monitoring will be better when the totalmix main output is close to 0db, and an analoge controller lowers the volume of the speakers, rather than having total mix main outputs moving between -50 and -30db, because of bit depth of the outputs. any insight on that or tip where to look at?
best,
jean
http://www.rme-audio.de/download/adi2dacr_e.pdf
Read chapter 31.14. After that look here:
https://forum.rme-audio.de/viewtopic.php?id=25399
again, exactly what I was looking for. thank you very very much!
I got 2 XLR-XLR 20db attenuators laying around, using them now, I guess they all work the same way and don't alter the sound...
