Topic: ADI-2 PRO FS Recording issues over 96 KHZ
I have a problem of recording with a sample rate over 96 Khz. The source is analogue (turntable )
I'm using a laptop windows 8.1 with Vinylstudio or Audacity. (Same issue with both of them )
The settings of the ADI pro are correct : USB mode, Clock source INT, and the selected sample rate is correct on the display.
On the laptop everything is fine with 96khz 24 bits. But as soon as I'm choosing a higher sample rate for example 192 Khz no signal is entering on the computer.
I made another test with another laptop on linux. Same issue.
It seems to me that the problem is coming from the ADDA.
I would be grateful for help.
Thank you
Re: ADI-2 PRO FS Recording issues over 96 KHZ
No signal or wrong noise signal? In that case you have set AD to DSD.
