Topic: Fireface UFXII & Soundforge
Hi, I have this problem: after stopping playback in Soundforge, the play cursor freezes and returns to the starting position after a while. This is very annoying when editing many items. I use RME Fireface UFXII sound card with ASIO driver. Does anyone know the solution so that the play cursor returns to the starting position immediately after stopping? I also work with DAW Reaper, and latency is fine. Thank you for your help.
https://imgur.com/2QOJ8t6
Re: Fireface UFXII & Soundforge
Its good that you compared with another DAW like reaper.
But you are not 100% clear on the point, whether you have the freezing cursor issue also in Reaper or not.
BTW .. What firmware and ASIO driver version ? Which version of Soundforge ? Numbers please not only "last".
Yes, everything's 100% okay in Reaper. Problem is only with Soundforge when I set the ASIO MADIface USB driver in options. If I use eg Windows Classic Wave Driver in Soundforge, it is also fine.
I use Soundforge version 13.0 (Build 124) 64bit and RME Fireface UFXII, ASIO 2.3 support, driver date: 01.11.19, driver version: 0.9700, Hardware Revision: 19
4 (edited by ramses 2020-02-22 08:46:07)
If RME does not have a better idea than me, then I tend to recommend to ask Soundforge Support
whether they have an issue in software.
I can not remember any post with a similar issue in the past years.
Tell Soundforge support the issue is only with an ASIO driver. Maybe they have an issue how to interface with an ASIO driver.
5
Does it help to reduce the ASIO latency? I have an older Soundforge 11 and do not see that effect.
