I use a basic setup:
1 macbookpro connected via thunderbolt to 1 UFX+ connected to 2 monitors via XLR.
DAW: Cubase 10
Cases:
1- There is no click when changing the sample rate directly in the dialog box of RME Thunderbolt Settings or FireFace USB Settings.
2- There is a click when changing the sample rate in Cubase
An example of case 2:
UFX+ is at 44100
Cubase is at 44100
Cubase opens a song saved at 48000
Automatically Cubase changes the sample rate of UFX+ to 48000
UFX+ makes a click (even when the output volume is muted in Totalmix)
The same happens when you change the sample rate from the song in Cubase. Example:
UFX+ is at 44100
I open a song that is configured at 44100 in Cubase
I change the sample rate of the song to 48000.
The worst situation is when you are working with 2 songs opened, one in 44100 and the other one in 48000.
Everytime you change the focus between songs, there is a click in monitors.
As I said in my initial post, I tried an Apollo and this device doesn't make this click.
So I thought you could add this feature to RME devices.
Summary:
I ask for a solution to mute clicks when the sample rate is changed from external applications.
Thanks in advance.
