Topic: AMD Ryzen X570 chipset problems
Hi all,
New member here. I read there are a lot of problems/compatibility issues with the new AMD X570 chipset.
This is not something RME or other companies can really do something about. As far as I have read several forums like Geraslutz and motherboard manufacturers this is a compatibility problem with the Agesa drivers from AMD.
I have an Asus Prime x570-P board which didn't boot after I built it. After finally removing my Firewire PCI-E card the system booted. That's how my search started and I came across a lot of other people having issues not only with Firewire cards but soundcards in general.
So now I'm also wondering if the RME HDSPe AIO PCI-E is working for others in a motherboard with X570 chipset.
I have read that Gigabyte released a beta bios which solved a lot of problems on some boards but Asus is just pointing at AMD as far as I can see.
Hope people can chime in and tell what works in their motherboard with x570 chipset.
Thanks in advance,
Andreas
