Topic: Solved: Raydat internal adat connection
I can't figure out which of the internal adat pins is ground. (Ray dat)
Usually RME clearly writes it on the cards, but here I cannot find the marking.
Any help?
thanks
klaus
RME User Forum → HDSP(e) series → Solved: Raydat internal adat connection
Any help?
thanks
klaus
I did a trial/error - Ground is the upper pin.
