Topic: Using Fireface, Protools and BlueCatAudio Patchwork
Hello all,
i'm struggling with something. I'd like to use Patchwork to put independent EQ on a surround (5.1) system. For this, i'd like to go out from Protools with the 5.1 channels on ADAT outs. I wired ADAT out to ADAT in on the fireface UCX. I patched  ADAT in to Analog out in Patchwork threw the EQ's i wanted. But Patchwork don't get the audio from ADAT in.
ADAT in is fed with signal when i look in totalmix, but as Patchwork works if i use another device (for example a Loopback virtual cable), i'm wondering if the Fireface accepts a second app wired on it more than Protools.
Any ideas about that ? I succeeded in using Loopback in addition to protools and wired the adat in to analog OUT in Loopback, but the architecture of Loopback is not the same than Patchwork, so i'm wondering if that would be the problem. I asked on blue cat's side, but was wondering if anyone had ideas here
If any lights on this please write !
thomas
Re: Using Fireface, Protools and BlueCatAudio Patchwork
Any idea from RME support ?
