Topic: Routing to play iTunes
Hi there,
I have successfully installed Total Mix FX with my Babyface Pro to digitize vinyl records
(i.e. using it for analog to digital conversion).
Routing is simple from instr. 3/4 input to AN 1/2 output and it works.
Hardware: turntable->phono pre-amp->input: instr. 3/4->USB-cable to iMac (recording with DAW software;
from Babyface pro AN1/2 output->active monitor speakers = listening to the vinyl record playing while recording it.
But how can I route it to listen to digital output (from my DAW software or from iTunes),
i.e. using the Babyface pro in the 'other direction' for digital to analog conversion
(Hardware: iMac->USB->Babyface pro-> AN 1/2 output->active monitor speakers)?
Hoping to find a solution here...
thanks
Richfield
Re: Routing to play iTunes
Just want to add that Babyface Pro is selected as standard input and standard output in Mac OS
system preferences>Sound
Shame about me... found out that the blue M button (top right under Babyface Pro) was activated -> muted
