Topic: Is There a MIDI command to...
Is there a Mackie Control/ MIDI command to perform the keyboard mouse combination of (on OS X) Alt + mouse click on a fader?
Many softwares use Shift + Click for this. This would be very useful to toggle a channel between unity and zero.
Kind regards
__________________________
Paul Najar
Jaminajar Music Production
www.jaminajar.com
Re: Is There a MIDI command to...
You can easily make your midi controller toggle between two values. Either using a programmable midi controller, or by using bome’s midi translator or similar sowtware in between your controller and TMFX.
Thanks for the suggestion although I don’t think it’s practical to have to dedicate one control of a mackie controller for this and also take it out of regular use. I was hoping for a more integrated solution rather than a custom one.
Paul Najar
www.jaminajar.com
