1
Topic: problems with setup (latency, crackles), win 10
As I was absent from this thematics for years, I now have serious problems and don't know how to solve.
I have problems with real time audio, main use playing an organ via a hdsp9632. It seems related to network and graphics.
I did try things like disabling various devices in the device manager but it didn't help.
Any hints, other programs for diagnostics...?
thanks
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for  0:01:12  (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name:                                        WORKSTATION
OS version:                                           Windows 10 , 10.0, build: 18363 (x64)
Hardware:                                             ASUSTeK COMPUTER INC., SABERTOOTH X79
CPU:                                                  GenuineIntel Intel(R) Core(TM) i7-4820K CPU @ 3.70GHz
Logical processors:                                   8
Processor groups:                                     1
RAM:                                                  32707 MB total
CPU SPEED
Reported CPU speed:                                   370 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs):   50949,80
Average measured interrupt to process latency (µs):   9,614742
Highest measured interrupt to DPC latency (µs):       50945,20
Average measured interrupt to DPC latency (µs):       6,541949
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs):              157,775135
Driver with highest ISR routine execution time:       dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%):          0,085389
Driver with highest ISR total time:                   dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%)                          0,134792
ISR count (execution time <250 µs):                   159867
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-999 µs):                0
ISR count (execution time 1000-1999 µs):              0
ISR count (execution time 2000-3999 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs):              9947,851892
Driver with highest DPC routine execution time:       netbt.sys - MBT Transport driver, Microsoft Corporation
Highest reported total DPC routine time (%):          0,046208
Driver with highest DPC total execution time:         dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%)                          0,196855
DPC count (execution time <250 µs):                   233700
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-999 µs):                3
DPC count (execution time 1000-1999 µs):              1
DPC count (execution time 2000-3999 µs):              9
DPC count (execution time >=4000 µs):                 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count:                 explorer.exe
Total number of hard pagefaults                       1477
Hard pagefault count of hardest hit process:          1246
Number of processes hit:                              5
PER CPU DATA
CPU 0 Interrupt cycle time (s):                       2,854716
CPU 0 ISR highest execution time (µs):                157,775135
CPU 0 ISR total execution time (s):                   0,775054
CPU 0 ISR count:                                      158820
CPU 0 DPC highest execution time (µs):                9947,851892
CPU 0 DPC total execution time (s):                   1,010229
CPU 0 DPC count:                                      229004
CPU 1 Interrupt cycle time (s):                       0,716527
CPU 1 ISR highest execution time (µs):                8,404324
CPU 1 ISR total execution time (s):                   0,000236
CPU 1 ISR count:                                      106
CPU 1 DPC highest execution time (µs):                7560,845405
CPU 1 DPC total execution time (s):                   0,023991
CPU 1 DPC count:                                      340
CPU 2 Interrupt cycle time (s):                       0,741618
CPU 2 ISR highest execution time (µs):                0,0
CPU 2 ISR total execution time (s):                   0,0
CPU 2 ISR count:                                      0
CPU 2 DPC highest execution time (µs):                5794,354595
CPU 2 DPC total execution time (s):                   0,045851
CPU 2 DPC count:                                      1703
CPU 3 Interrupt cycle time (s):                       0,43730
CPU 3 ISR highest execution time (µs):                5,760
CPU 3 ISR total execution time (s):                   0,001110
CPU 3 ISR count:                                      941
CPU 3 DPC highest execution time (µs):                26,862703
CPU 3 DPC total execution time (s):                   0,000734
CPU 3 DPC count:                                      153
CPU 4 Interrupt cycle time (s):                       0,592427
CPU 4 ISR highest execution time (µs):                0,0
CPU 4 ISR total execution time (s):                   0,0
CPU 4 ISR count:                                      0
CPU 4 DPC highest execution time (µs):                8481,758919
CPU 4 DPC total execution time (s):                   0,037987
CPU 4 DPC count:                                      685
CPU 5 Interrupt cycle time (s):                       0,392455
CPU 5 ISR highest execution time (µs):                0,0
CPU 5 ISR total execution time (s):                   0,0
CPU 5 ISR count:                                      0
CPU 5 DPC highest execution time (µs):                52,244324
CPU 5 DPC total execution time (s):                   0,002290
CPU 5 DPC count:                                      238
CPU 6 Interrupt cycle time (s):                       0,501509
CPU 6 ISR highest execution time (µs):                0,0
CPU 6 ISR total execution time (s):                   0,0
CPU 6 ISR count:                                      0
CPU 6 DPC highest execution time (µs):                87,038919
CPU 6 DPC total execution time (s):                   0,008977
CPU 6 DPC count:                                      1137
CPU 7 Interrupt cycle time (s):                       0,413411
CPU 7 ISR highest execution time (µs):                0,0
CPU 7 ISR total execution time (s):                   0,0
CPU 7 ISR count:                                      0
CPU 7 DPC highest execution time (µs):                39,883243
CPU 7 DPC total execution time (s):                   0,003828
CPU 7 DPC count:                                      480
Re: problems with setup (latency, crackles), win 10
ok, a first success: the PhysX setting/software on my nvidia graphics crad was one culprit. I changed setting from "auto" to the graphics card itself (didn't find a way to deinstall/deactivate it) and now the spikes related to graphics are completely gone.
I do have a better result, but no there's the "red" ndis.sys from time to time. Will see if I get rid of that also.
