1 (edited by Hinfoweb 2020-04-12 20:34:29)
Topic: Latest Driver 4.30 in hdsp 9632 not recognized in Windows 10
I think it's the first time that happens .. Today I downloaded the latest 4.30 audio driver for 9632 hdsp on the latest updated version of Windows 10: the installation went well the plugins in the taskbar appeared, as always, but in the panel controls have not appeared, and have not been recognized ... So no sound ... Fortunately I had saved version 4.29 otherwise now I would be without audio ... 4.29 works correctly. Thank.
https://efrem-c-79.wixsite.com/efrem-c-79
Re: Latest Driver 4.30 in hdsp 9632 not recognized in Windows 10
Deatils please - what panel? What controls? I had tested the driver and saw no problem anywhere.
Hi there,
exactly the same problem here with hdsp9632 but Win 7/64.
audiocast
You could have answered my question, though...
5 (edited by lagardamusica 2020-04-13 11:50:11)
The Same with HDSP 9652 with windows 7 / 64Bits
The Control Panel of DSP don't open
The TotalMix don't open
in the device manager tell me that there are a problem with digital signature
Luis
windows 7/ 64bits
Hi MC,
1. the Control Panel doesnt  open
2. the TotalMix doesn't open
3. the device manager reports a problem with digital signature.
thanxX.
7
Thanks, we'll check that.
Same with HDSPe expresscard with multiface II in windows 7 pro 64-bit.
Installed latest driver 4.30 and the device is shown with exclamation mark with device status:
"Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)"
Will use 4.29 for the time being.
Thanks MC!
9
We are working on getting the digital signatures compatible to Windows 7 again. The formerly used signature expired, 4.30 includes a new one. While we can reproduce this on Windows 7 we can't on Windows 10, and there is no reason it shouldn't work with Windows 10 unless you have disabled internet access and use an older, not updated OS version. Then the signature engine might not be up to date.
I uploaded a new version (rmeinstaller.exe date from today, driver date itself is not changed) that worked on my Windows 7 computer. Please try if it works for you as well.
http://www.rme-audio.de/downloads/drive … in_430.zip
Thanks MC. Installed successfully here on W7. (Was not originally)
Hi MC, thanks for the link it worked great! (windows 7 from above)
Works Great
Luis
windows 7/ 64bits
Multiface I not recognized under windows 10 with today's 4.30 driver, The soud is set to AMD graphic card, Multiface is not available.  rolled back to 4.29.
System:
I5-9400F
Windows  10 64 bit
gibabyte Z370P D3 motherboard
15
No audio device is installed because the number of WDM devices is reset to 0 in the Settings dialog. Try again...
Installed 4.30, selected  the WDM  devices after reboot  , everything works great.  Thank you MC!
Cant get it to install at all...
http://www.brettrader.net/images/RME-Fail.jpg
This has never happened before.
18
More details are found in the file C:\Windows\DPINST.LOG.
19 (edited by brett_rader 2020-04-26 02:50:06)
INFO:   04/25/2020 20:46:50
INFO:   Product Version 2.1.0.0.
INFO:   Version: 6.0.6000
INFO:   Platform ID: 2 (NT)
INFO:   Service Pack: 0.0
INFO:   Suite: 0x0300, Product Type: 1
INFO:   Architecture: AMD64.
INFO:   Interactive Windows Station
INFO:   Command Line: 'C:\Users\brett\AppData\Local\Temp\rme\dpinst64.exe'
INFO:   DPInst is not multi-lingual.
INFO:   ****************************************
INFO:   Current working directory: 'C:\Users\brett\AppData\Local\Temp\rme'
INFO:   Running on path 'C:\Users\brett\AppData\Local\Temp\rme'
INFO:   User UI Language is 0x409.
INFO:   Install option set: Force install if driver is not better.
INFO:   Install option set: uninstall will be set to delete driver binaries.
INFO:   Found driver package: 'C:\Users\brett\AppData\Local\Temp\rme\hdsp.inf'.
INFO:   Preinstalling 'c:\users\brett\appdata\local\temp\rme\hdsp.inf' ...
INFO:   ENTER:  DriverPackagePreinstallW
INFO:   Driver package is already preinstalled 'c:\users\brett\appdata\local\temp\rme\hdsp.inf'.
SUCCESS:c:\users\brett\appdata\local\temp\rme\hdsp.inf is preinstalled.
INFO:   RETURN: DriverPackagePreinstallW  (0xB7)
INFO:   ENTER:  DriverPackageGetPathW
INFO:   RETURN: DriverPackageGetPathW  (0x0)
INFO:   ENTER:  DriverPackageInstallW
INFO:   Installing INF file 'c:\users\brett\appdata\local\temp\rme\hdsp.inf' (Plug and Play).
INFO:   Looking for Model Section [Devices.NTAMD64]...
INFO:   Installing devices with Id "PCI\VEN_10EE&DEV_3FC5&SUBSYS_00000000&REV_9B" using INF "C:\WINDOWS\System32\DriverStore\FileRepository\hdsp.inf_amd64_241167a7ddabefc5\hdsp.inf".
INFO:   ENTER UpdateDriverForPlugAndPlayDevices...
ERROR:  RETURN UpdateDriverForPlugAndPlayDevices. (Error code 0xE0000246: One of the installers for this device cannot perform the installation at this time.)
ERROR:  Installation failed. (Error code 0xE0000246: One of the installers for this device cannot perform the installation at this time.)
ERROR:  PnP Install failed. (Error code 0xE0000246: One of the installers for this device cannot perform the installation at this time.)
INFO:   Attempting to rollback ...
INFO:   No devices to rollback
INFO:   RETURN: DriverPackageInstallW  (0xE0000246)
INFO:   Wizard cancelled by user on welcome page.
INFO:   Returning with code 0x80010000
INFO:   04/25/2020 20:46:55
Looks like I'm pretty much dead in the water now.  Device manager shows my 2 hdsp9632 cards as "Multimedia Audio Controller" with no driver installed.  The installers for 4.30 and 4.29 both fail.
20
Remove both cards, clean their PCI gold contacts with a soft rubber eraser, then insert only one card and try to install the driver (unless that doesn't automatically happen). If it worked add the second card...
21 (edited by brett_rader 2020-04-26 13:01:10)
Thanks for the reply.  Installer finished, but the cards are still not recognized.
22
How exactly are they 'not recognized'?
In Device Manager, they used to show under Sound, video and game controllers as HDSP9632.  Now they show up as Multimedia Audio Controller with no driver attached.
http://brettrader.net/images/9632.jpg
24
The cards are either defective, or the motherboard is, or there changed something in the system/OS or BIOS. It seem the cards Device ID is wrong and doesn't match the one in the driver, so the driver is not loaded for them.
For the above: If you go to Properties / Details, what Hardware ID is shown there?
25 (edited by brett_rader 2020-04-26 22:28:36)
Well, I've got it working.  I removed the cards, removed all RME drivers with "Programs and features", reinstalled the 4.30 driver, Reinstalled the cards, and voila, everything works as it did before, but with the new driver.  Thanks for your help, you triggered some ideas for me to try.
http://brettrader.net/images/9632B.jpg
I know these cards are old, but I really love them.
brett_rader wrote:
Well, I've got it working. ...
Good to hear that you got everything sorted now, Brett! I've got one of these up and running, too - never had a problem, except for finding motherboards with a pci slot. Fantastic mileage on these soundcards, cudos to RME for making computer hardware with a lifespan that is surreal in the computer world.
I've also got one of the extra output daughter-boards connected to my HDSP 9632.
/Magnus
I apologize if not I have replied but I really forgot, then I had formatted the PC and I no longer thought about this problem. I also tried the latest version but it always gives me the same problem. The icons appear correctly in the taskbar and open normally. But the audio is not recognized in the audio settings of Windows 10. I have therefore only the HDMI audio of the video card and no Rme.
28
Post 15.
Ok. Thank.
Got the same issue today, RME ok but not showing in W10 sound cards on both PCs here
Thank you Matthias for post 15, this is the fix !
