Topic: Why does TotalMix not show all Inputs/Outputs of my Babyface Pro?
I've got a quick question: TotalMix somehow does not show all Inputs and Outputs of my Babyface Pro. For instance in the hardware inputs row it just goes until ADAT 3/4 (ADAT 5/6 and ADAT 7/8 are not visible). Same goes for the software playback and hardware outputs rows. I already thought that I might need to click a show/hide button or something, but that wasn't the case. I would really appreciate some help. Thanks.
Kind regards
Re: Why does TotalMix not show all Inputs/Outputs of my Babyface Pro?
Do you have sample rate set to 96khz? It will only show available outputs at any given sample rate selection.
3 (edited by sizeof 2020-04-15 20:55:23)
Yes I do have it set to that sample rate. What do I have to do? Do I just need to change the sample rate? If so, to what? Thanks
You were right, I changed the sample rate to 48kHz and now all ADAT outputs appeared. Thank you very much!
