1 (edited by lukasecho 2020-04-16 08:10:20)
Topic: 2020 is an original Multiface I + Cardbus (PCMCIA) usable today? MacOS
I have searched but can't find a definitive (or recent) answer.
What would be the cheapest and most reliable way in 2020 (if any exists) to use an original RME Multiface I w/ flat Cardbus (PCMCIA) adaptor with a modern computer (preferably a MacOS).
I realise that this interface is probably almost 20 years old -- It has been in my basement for 5 years or so, but thought I might be able to resurrect it. A few years ago, it seemed like I would need first need to get the RME HDSPe ExpressCard adaptor (or HDSPe PCIe  for a desktop computer) since Cardbus is absolutely obsolete.
ie. the flat version of this: https://archiv.rme-audio.de/en/products … erface.php
It seems that even the  HDSPe ExpressCard is no longer available:
2 (edited by vinark 2020-04-16 08:46:29)
Re: 2020 is an original Multiface I + Cardbus (PCMCIA) usable today? MacOS
I can only tell you for windows...
Get a PCI based quad core like a Asus P5Q mobo with q9550. Then (or first) a PCI to carbus adapter. 8gb ram. This will work pretty good with win7 or 10. (I have such an adapter for an old echo indigo cardbus audio card, works 100%)
You can get a newer PC with PCI slot and a PCi to cardbus adapter, but I know the P5Q series work. cause I use them daily (with hdsp9652 PCI).
But it is a lot easier if you get a usb RME interface which will work with any computer.
I don't think this will work for mac as there were never any PC's with PCI (or cardbus) with OSX. SO you would need a PCIe hdspe card for that.
…works like a charm on a 2018 mbp…but you needsome adapters (and of course the hdspe card from rme):
- thunderbolt3 to thunderbolt2 adapter from apple
- then this: https://www.sonnettech.com/product/echo … rbolt.html
bam...20 year old mf1 still working in 2020!
…and you could also use the mf1 in conjunction with a pciexpress card inside this:
https://www.sonnettech.com/product/echo … rview.html
There are no Intel Mac based drivers for the HDSP Cardbus card, sorry. This won't work, even with an adapter. On a Windows system, it will...
