Topic: RayDat Card - Can't Get Stereo Monitoring In Headphones
Hello all,
I'm using the HDSPe RayDat card with a brand new Focusrite Scarlett Octopre Dynamic, and Presonus Central Station for monitoring and playback.
The option on my DAW for SPDIF output is only monitoring sound to the left stereo channel on my monitors and headphones.   The track I am testing with is a mono track mixed into the stereo master of the DAW, which all shows stereo output, but when it hits total mix, and then my Central Station, it's only the left side I get sound on.   On playback the sound is in stereo, this is ONLY when monitoring I have this issue.
I am bewildered and I'm hoping this is an easy fix.   If you want to know, yes I do have "SPDIF Out" set to ADAT 4, and I am using a TOSLink cable from ADAT 4 to my central station.
Any help is appreciated, thank you!
Re: RayDat Card - Can't Get Stereo Monitoring In Headphones
To add to the information, I've also now attempted using an SPDIF cable, with the same result.
If the issue already shows up in the software playback channels of Totalmix, it would likely be a configuration issue in your DAW....
Is that the case?
Unfortunately not, as the signal only turns into the Left channel when it hits total mix.
Also when playing back the recording, it plays in stereo with no issue.
This is only when monitoring through total mix, the DAW has absolutely no part in it.
5 (edited by ramses 2020-04-21 15:14:27)
bubingaisgod wrote:
This is what it looks like, no DAW open, just my Octopre Dymanic hooked up via ADAT to the RayDat card,
monitoring through totalmix into the Central Station.
https://drive.google.com/open?id=1HPiwo4YsjML7bSdNFpewsyJZpboNM4Cv
https://drive.google.com/open?id=1R0cvBKSuYQ22A6zFUww3OYGuBh3DUZkB
The URLs are neither clickable nor copy/pasteable. Please fix, otherwise they are of no use, thanks.
The url forum tags should do ...
6 (edited by bubingaisgod 2020-04-21 16:05:29)
Here is the URL tag
https://drive.google.com/uc?id=1HPiwo4Y … JZpboNM4Cv
https://drive.google.com/uc?id=1R0cvBKS … GuBh3DUZkB
https://scontent.ftpa1-1.fna.fbcdn.net/ … e=5EC52DF6
https://scontent.ftpa1-1.fna.fbcdn.net/ … e=5EC307CD
8
I don't get it. Pan(orama) is dialed to left, so what is wrong here?
Thank you!  SPDIF was also somehow panned left, I never touch those knobs so I have no idea how that happened, but it's solved, and I thank you kindly!
