Topic: UFX + Dangerous Dbox + Mac mini 2018
Hello everyone,
New to the forums here so please forgive me if these questions have already been asked. I've searched every where for a solution to my problem but can't seem to find anything similar to the situation I'm experiencing with my newly purchased Mac mini in conjunction with my set up.
I'm running an RME UFX with a Dangerous Dbox into a new 2018 Mac mini. I know I know... there have been known issues with the Mac mini but all the issues I saw dated back to the beginning of 2018 through till middle of 2019. Most of the posts regarding the issues were almost a year old as well so I figured the issues have been resolved by now.
My first issue is with my routing from the RME to the Dbox. Before the Mac mini, I had this rig hooked up to my late 2014 MacBook Pro. I followed the instructions from Dangerous Music and set up total mix exactly as I was shown. I set my main outs to outputs 13/14 AES and I was off to the races. All my system audio came out the DAW function of the Dbox and all my summing was sent to SUM as intended.
After setting up my Mac mini today, I noticed that my RME was not behaving in the same way with my Dbox as it had with the MacBook Pro. The main system output seems to be coming out of AN 1/2 and setting my main outs to AES does not send any signal through my AES connection. I'm wondering if this is a clocking issue or perhaps an issue with the newest driver which I installed from RME website. I can't seem to wrap my head around this.
I tried to turn off the UFX and power everything back up to see if it would sync but still nothing. With my MacBook Pro, I had AES working flawlessly and "SUM" on the Dbox would only have signal going through it if I routed my track outputs in Ableton to the respective Dbox SUM inputs. I'm puzzled as to what's going on and I even replicated the exact same settings in TotalMix FX that I had on my MacBook Pro.
I also don't know if it has to do with the issues surrounding USB 2.0 devices in the Mac mini usb 3 connector so I'm hoping someone can shed some light.
My third and final issues is with the Mac mini restarting itself at times and saying there was an error and to report it to Apple. I'm again assuming it has to do with the RME hooked up to the USB 2.0 device since apple says this error comes up when there is an issue with hardware.
Can anyone assist or shed some light? Anyone have a similar set up? I can't return the MacMini but I can trade it in for something else in the next two weeks but for the price I figured this machine would be a power house for ITB production.
Look forward to hearing back and hoping I can find a solution.
Thank you
