Topic: Is it possible to control physical switches with ARC via MIDI relay?
Scenario:
Speakers that have a physical foot switch input for a certain function, that could be controlled with ARC.
A device such as this:
https://www.thomann.de/intl/si/voodoo_l … itcher.htm
https://www.thomann.de/intl/si/midi_sol … lay_02.htm
could then be connected to the MIDI Out of UFX or something.
So, MIDI to switch part is solved.
Selecting a snapshot would then send a MIDI message to open/close the physical relay/switch.
is that possible?
