Topic: Power Supply
Two bad those little black things aren't as tough as the blue things. PS about to die and I am just about to FREAK OUT!!!!
Thank you MC for putting the bus power switch on the FF400. Thank you thank you thank you thank you for everything. It saved me today because for some bizarre reason my last functional ps decided to not light up. But I was still able to record for 2 hours straight with no glitches while I whacked every key on a Fender Rhodes MK I Stage.
I guess I need to download the manual to see if it's center pos or neg while 12v 2amp.
And they aren't cheap!
