Topic: HDSPe MADI FX last eight inputs disappeared from TotalMix
The title says it all. My inputs stop at 184 and the last bank of 8 inputs is not seen by TotalMix.
All Playback and Output channels are available and the inputs are not hidden in the channel layout.
I tried resetting TotalMix to no avail. Curiously Audio/MIDI Setup is still showing the inputs as is Reaper.
Currently the device connected to the third MADI port on my HDSPe MADI FX card is 56ch so I cannot test whether or not the missing 8 oinouts work.
The card has been working fine (and continues to do so) and I am on macOS 10.14.6 firmware .91 driver 1.28 and TotalMix 1.64
2x HDSPe MADI FX, MADIFace Pro
Re: HDSPe MADI FX last eight inputs disappeared from TotalMix
64 - 56 = 8. How can there be inputs that don't exist? Connect a 64 channel source and they will be back.
That makes sense - I was not aware That TotalMix automatically adjusted inputs (and presumably outputs) according to what is connected hardware wise.
