Topic: RME UFXII doesn't show up in Windows Audio settings
Hello
I have my UFXII connected via USB to my PC (Windows 10). I work in Cubase, everything is fine, I can select the RME device there as usual.
But I can't select the UFCII as an output audio device in the Windows system settings (it just doesn't show up). So if I want to listen to an audio file in Quicktime, for example, it won't sound...obviously I don't always want to import every audiofile to cubase first in order to listen to it.
In the Device Manager under Audio the RME UFX II is listed as normal. I have also installed the latest driver.
What to do?
