Topic: Loopback working only for Analog Outs
Hello, I was hoping someone could help me out with this.
Im trying to record separate outputs from one instance of Ableton Live , which I will call A, to another instance of Ableton Live , which I will call B. (B will act only as a multitrack recorder)
If I use any of the analog outputs in loopback mode for this purpose, the signal will show up on B and I will be able to record it. However, if I use any of the digital outputs, B will not see any signal, even though it is clearly visible in Totalmix.
I need the analog outputs for other purposes, so it would be great to be able to record the loopback from the digital ones.
What am I missing here?
Thank you.
