1 (edited by darkhajun 2020-06-09 10:28:40)
Topic: Connecting FF802 ADAT2 output to Digital speaker directly
I connected the ADAT2 output of FF802 to general digital speaker's input directly
using SPDIF Cable.
I expect when I send the sinewave to ADAT2 output,
digital speaker will play that sounds directly but I'm not getting any sound.
Speaker is not muted.
TotalMix shows me that sinewave was sending to ADAT2 rightly.
How can I play the sound of ADAT2 of FF802 through the digital speakers?
Are there any conditions to set?
I hope my capture of setting status is uploaded under this line.
https://blog.naver.com/darkhajun/221995238199
Win7/Fireface802/ADAT2(Using only one channel now)/SPDIF cable/direct connect to speaker
Fireface USB Settings :
Buffer size = 4096 samples
ADAT2 Out = AES/SPDIF
AES Input = AES
AES Output = Consumer
Sample Rate = 96000
Clock Source = ADAT2
Pitch = 0%
Re: Connecting FF802 ADAT2 output to Digital speaker directly
This is an incorrect routing. You have to route the signal to the AES Out channel, then this signal on the AES/EBU XLR output is copied to the ADAT 2 output working in optical SPDIF mode.
Thank you Jeff. Thanks to U I solve the problem.
