Topic: Babyface Pro FS - puzzling behavior with DI and line input signals
Made a move recently from Focusrite Scarlett 2i2 gen 1 to RME BF PRO FS. Enjoying a significant upgrade across the board, except for a single issue with tracking bass guitar for parallel processing inside DAW.
My setup is simplistic: passive bass into Darkglass B7K preamp, which outputs 2 signals: processed output into BF input 3 (line), unprocessed DI output into BF input 1 (mic). Using mono unbalanced cables for everything.
When monitoring each signal isolated (not picking the other signal from B7K, cable is unplugged), everything seems to be fine - I'm getting audio in BF as expected. However, as soon as I have both signals going out of the pedal, BF gets lower volume and quality signals on both inputs. It appears as if the mic input 1 signal affects line input 3 signal inside BF itself.
The same setup worked fine with Focusrite Scarlett - B7K processed output into line in, DI output into mic/instr in, all good, latency aside
What am I doing wrong?
