Topic: MIDI problems with FF400.
So everything is working fine apart from a lil struggle with totalmix FX  at first but OK now. However the MIDI is not getting to my DAW’s? I have the break out cable using port 1 and set my daws’s to midi channel “any” but no midi registering. any thoughts?
Mac Mini 2012
MAC OS X Catalina, 16 GB RAM,
Logic Pro X and Cubase Pro 10.
Re: MIDI problems with FF400.
Outdated driver? Checked Audio MIDI Setup?
Aha, good thinking Batman
Ok I checked the audio MIDI setup and the driver...all up to date/but still no midi
5
Then in that dialog reset the MIDI devices and let macOS search for them again.
Reset of MIDI devices has not solved the issue. I have also noted that the FF400 firmware has an update but the update app will not open in Catalina. I’m also wondering if it’s the break out cable...s’pose I can get my multimeter out!
will there be an update to 64 bit or do I have to use an older 32 bit computer?
8
I seriously doubt that you have a unit with an older firmware than the one  on our website. Version 1.71 is from 2010.
But I can’t update to that firmware cos it won’t install on Catalina. I starting to think I need a more up to date interface.why is it telling me I have to wait silty seconds between postings and I haven’t posted anything?
