Topic: Zero Latency Monitoring
Can someone please point me in the direction of instructions as to how to set up zero latency monitoring?
I'm using an RME Fireface UFX, W10, and Cubase. But really I'm just looking for a clear general explanation.
Thank you.
Re: Zero Latency Monitoring
This is when you route the I ports of the Interface (TM FX Top Row, "HW Inputs") to the HW outputs.
Then everything goes ultra fast through the internal routing matrix of the recording interface.
Everything which goes through USB has to go through USB twice (RTL, round trip latency) which also depends on ASIO buffer size and sample rate.
Thank you. I guess I thought it was going to be something much more complex.
For example, I thought it had something to do with the Loopback feature.
