Topic: Input gain issue
Hi there! I'm using Babyface Pro and all guitars with humbuckers I've tried (4-5) are clipping through instrument inputs with gain knob set to 0 in +4db mode. What am I doing wrong? What should I do to reduce input gain level? Clipping is not critical, it only appears when I'm picking a bit harder, but it happens pretty often. Here's a link to a short DI clip just in case. Attack is exaggerated a bit just to show - https://dropmefiles.com/TvPYI
Thanks for any help! All the best
