Topic: HDSP 9632 (PCI) to use on a PCIe slot?
hi,
we don´t want to sell our loved HDSP 9632!
We build a new PC with this MotherBoard:
Asus Rog strix x470-f gaming
Is it possible to us an adapter, internal or external, to connect the PCI Card to a PCIe Slot and if yes, which one?
Does the card work proper then?
Thank you in advance
2 (edited by hamanohashidate 2020-07-05 23:41:19)
Re: HDSP 9632 (PCI) to use on a PCIe slot?
it looks like some compagny do it :
https://www.startech.com/Cards-Adapters … y~PEX2PCI4
and it seems to work as someone sell it on ebay with 2 9652 :
https://i.postimg.cc/Hny5cTTf/s-l1600-2.jpg
https://www.ebay.com/itm/RME-Hammerfall … SwQURei1of
Looks great but this is far to expensive big_smile, nearly the price of a new 9632. And we need only space for one PCI Card at all smile
https://www.amazon.com/Sintech-Express- … asin_title
This works I am told. Also available on ebay and alibaba.
Yep. I used that Sintech adapter with my 9652 and worked great (at least on Windows 7).
Ok, thank you guys smile So we can try it. I ordered this one:
https://www.amazon.de/gp/product/B00KZH … &psc=1
Hopefuly it´ll work smile
7 (edited by RIKAAR 2020-07-13 22:09:28)
did not work...or does it only work with an actual firmware? I dont know the actual firmare...
We use Windows10 64 bit
Dear All,
I got a similar adapter but the connection does not fit physically.
what does not fit?
StarTech.com adapter does the job perfectly. Tested! 9632 installed on GigaByte Aorus mobo. Win 10. Full tower case. Worked instantly. No additional modifying. No problems with reaching the connector because I'm using only analog in/out socket.
Ordered similar (much cheaper) adapter from Ali first - and got only heavily distorted crackled signal out. tongue
Bought here
https://www.amazon.de/-/en/dp/B0024CV3SA
https://forum.rme-audio.de/viewtopic.ph … 42#p125842
