Topic: USB- Variable Sound Quality (Inconsistent)
I am new owner of an ADI-2 DAC FS. I seem to be having an issue with the USB input. I am using a SOTM SMS-200 to stream to the DAC through USB. When I first hooked it up, the sound was somewhat distorted, like it was missing data (microdropouts?). I then ran a Coax from a Sonos I have and it sounded fine. I rebooted the SOTM and it sounded better (I can cue up the same music at the same time in Roon and instantly switch inputs between the SOTM and Sonos to compare). A while later the gritty sound came back. I unplugged the USB cable and reconnected and it is better again.
Any ideas? Connection issue? Update firmware on the RME (which I assume is pretty current).
Thank you,
Cary
