Topic: Adat cable for 9652?
Hey guys, how are you?
I´m getting some troubles (noise) with adat cables hanging a bit loose on my (older) 9652.
Is there a particular cable or solution to avoid this issue?
Thanks!
RME User Forum → HDSP(e) series → Adat cable for 9652?
Thanks!
If its only the plug, Mutec cables have good plugs
https://www.thomann.de/de/mutec_optisches_kabel_1m.htm
