Topic: SOLVED - Latency Problems between UFX and OctaMic II
Hi!
I'm using a UFX as my Interface and a OctaMic II via Adat 1. I recently recorded a double mic'd instrument with one mic going through each piece of gear and noticed there was horrible phasing going on. Upon further investigation I figured out the OctaMic has a 35 sample latency. Does anyone know this problem and have an idea how to fix it within the RME system (i.e. in the hardware or totalmix)? I don't want to manually move tracks after recording or do anything in my DAW if not necessary...
Thanks in advance!
