Topic: Using Mutliface II with Multiface I via ADAT
I got a Multiface connected to a Multiface II via ADAT. The Multiface II ist connected over PCIe to my PC and the Multiface has a PSU. When I connect the Multiface to the PC all inputs work. I used the disconnect function on the HDSP Settings, restart and now connect the the Multiface II. HDSP Settings show ADAT Sync but I don't get any input on the ADAT Channels. What am I doing wrong?
MSI X58 Pro i7@930, 12GB
W10 Pro x64, Reaper, Wavelab
5x MF II, 5x MF
E-mus and many other animals
Re: Using Mutliface II with Multiface I via ADAT
The unit does not automatically send signal to ADAT - you will have to manually set the desired routings in Totalmix before you disconnect...
D. Fuchs
I feel stupid now... Thank you!
5x MF II, 5x MF
