Topic: BabyFace : overdriven AD at USB-BUS-powerOver drivng the INPUTS (OVR)
'vintage' BabyFace still well used ...
Over driving the INPUTS (OVR) may result in long lasting disturbances at the ADconverter.
This seems to happen only if PHANTOM is enabled and unit is USB-bus-driven.
Switching OFF phantom and/or using a seperate mains-supply will help.
-akl-
Re: BabyFace : overdriven AD at USB-BUS-powerOver drivng the INPUTS (OVR)
Not enough USB bus power. Use the included 2 connector cable or an external power supply.
